Old 01-30-2022, 05:42 PM   #17
FED 387
Liked 333 Times in 180 Posts
Default Re: 79 Malibu- Stocker-Stick Shift
heim ends are the only way to go also make up a piece of tubing to go from the Z bar to the fork and put left and right hand threads so you can use helms along with lock nuts--- makes adjusting so much easier PLUS no way that its going to fall out of the assembly---FED 387
