Old 01-28-2022, 10:43 PM   #2
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Default Re: Past NHRA national Results
If there is, I certainly haven't found it.
The best source I've found is the "Nostalgia Stock & Super Stock" section here. Results are scattered. No particular order whatsoever.
Sometimes you'll find class winners, sometimes entry lists, sometimes nat record holders, sometimes event winners.
I suppose if you have LOTS of time & are very patient, you could go thru & pick out all the info of interest to you & compile it into some sort of order, so that you could find it quickly, if you wanted to. Would be quite a project.
