#1 | |
Liked 524 Times in 141 Posts
Could be all wet, but this is why I think we see changes like these. This is not to be read as I agree with the simplification for them to do their job. |
Liked 2,723 Times in 960 Posts
You're correct about their ability to properly check Cam Duration and shame on the N.H.R.A. for that. Greg Xakellis had a great team then and it was not a D1 issue and I doubt it was a D3 or D4 issue either as they also had great teams as well. But the Valve Springs? Come on man, anybody can check spring pressure.
Liked 169 Times in 53 Posts
Put the "stock" back in "stock".... good start would be Pressure on valve springs.
Bill Bogues 4696 STK |
Liked 497 Times in 243 Posts
The point, however, is that if a 750-850 HP, 358 CID, canted valve, flat tappet engine in a Cup car can run 500 miles at over 9000 rpm with a stock diameter solid lifter, then it's hard to imagine why it can't be done in a stocker that doesn't anywhere near that RPM and is raced a quarter-mile at a time.
You're still comparing apples to grapes... The technology used to make a NASCAR engine live is so for advanced it makes a SS engine look like a high school mechanics class project. |
#6 | |
Liked 7,730 Times in 1,739 Posts
OBTW, ANOTHER reason to appreciate those "old" Tech guys!
Liked 10,703 Times in 2,229 Posts
I for one have had, lifter problems both ceramic and steel, cast core cam failure, and an oil pan full of steel shavings from a ceramic lifter failure on a steel cam. Each time a failure occurred we lost everything but the heads, intake, rods, and sheet metal. I put eight sleeves in a block, the block broke after a few runs. So we , a bunch of smart people that have helped me, have attained a small amount of reliability with the six pack car.
The cam is factory size journals and lift I know the other shoe will drop sooner but I hope it later. |
