Old 01-04-2022, 09:43 PM   #1
Terry Cain
Terry Cain's Avatar
Liked 230 Times in 106 Posts
Default Explain to me again, please
Why are (some not all) stockers still running flat tappet lifters when a motor with flat tappets ain't been made in 20 years and a set of tool steel lifters is $2100, 4-6 months back order . Guess my old head just don't see the reasoning or the difference between lifters and rockers. .
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 01-04-2022, 11:39 PM   #2
john ancona
john ancona's Avatar
Liked 185 Times in 56 Posts
Default Re: Explain to me again, please
You only have to go back to 1/15/2016 on this site to see my post about this topic , one can clearly see that NHRA has implemented rule changes that changed everything in the valvetrain but the lifters , lifters the became the weak link , many racers not only have told ,and showed NHRA over ,and over again over many years ,not weeks or months for years now the destroyed engines ,pistons ,cams ,and lifters costing racers a lot of money needlessly , if they would have left the rules in place on the valve train in the first place we would not be waiting months for ordered lifters today !
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 01-05-2022, 12:09 AM   #3
1347
1347's Avatar
Liked 995 Times in 275 Posts
Most don't want solid roller cams in stock, just go back and read posts about it in the past. Opening up that box will get you one more step closer to making a stocker engine a super stock engine with a lift rule.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 01-05-2022, 12:36 AM   #4
Rory McNeil
Liked 1,103 Times in 301 Posts
They haven`t made an engine with a carburetor in about 35 years neither, do you suggest all older Stockers should be allowed EFI as well? Also been over 20 years since Chevy built a non LS small block, do you suggest LS engines for old cars? I personally believe that NHRA has allowed far too many superseded/approved/updated parts to the "STOCK" class, be nice if at least some semblance of "STOCK" components remains, before it turns into an anything goes bracket class. If you just have to have a roller cam, there are plenty of combinations that came with them from the factory, to chose from.
NHRA 6390 STK
M/S 85 Mustang
Old 01-05-2022, 03:16 AM   #5
john ancona
Then put the rules back ,and most will wine about that , in case you haven't noticed stock is already Super Stock ,the lifters will not change fact that stock has gotten way out of hand ,you stated Open up that box will get one more step closer to making a super Stock engine with a lift rule , well, you and others better look again if we are only the lift rule away if we change the lifters what about the other enhancements to stock over the years to get us all to this point ,You freely use the word most ,would they be the guy's that are cheating spending lot's of money to cheat are they the ones that you call most ! The point you ,and others are missing ,and it is still the same as it was back in 2016, and even before that the old cars are at a disadvantage you ,and others may just want to see them disappear while you drive a late model race car with roller lifters ,and have others that can't aford to keep dealing with the lifter problem !
Old 01-05-2022, 08:28 AM   #6
Billy Nees
Liked 7,721 Times in 1,738 Posts
Ya piks yer kombo and ya pays yer dooz.
If you want a roller lifter combo with EFI then that's where you start.
Billy Nees 1188 STK, SS
Old 01-05-2022, 10:21 AM   #7
Terry Cain
Terry Cain's Avatar
Maybe we need a poll because MOST (from my outlook with all the new motors available) are already running solid rollers. They wouldn't need to vote. It looks to me like the only ones not running them are the cars from 60-early 80's. At the rate of $2100 a set and 6 months wait time for tool steel lifters they can lower the entry to 30 and 95% will be roller motors. If I have to qualify for a event spot against a non-vin, state of the art, factory made race car at least make it fair for the old flat tappet cars.
Terry Cain ???? STK
Old 01-05-2022, 10:36 AM   #8
Billy Nees
Soooooooo.......... you don't care about qualifying being "fair to the old flat tappet cars", you care about it being "fair" to you!
Here's a "fair" way to make this work without affecting anyone else, why don't you go and buy a "non-vin,state of the art, factory made race car"!
It's thinking like THIS that has S/SS in the screwed up state that it's in and why there needs to be some re-thinking and some back-tracking of some of the rules by NHRA and Tech.
Old 01-05-2022, 11:05 AM   #9
SDT1DYI
Liked 454 Times in 147 Posts
Just like after market heads, if you car did not come with Roller lifters, if you want to run them, add an additional 5 hp to your
Combo.
NHRA should have implemented other HP adjustments for several other non OEM approved engine parts.
Would of leveled the playing field in Stock.
Steve Teeter Stk/SS 620
SDT1DYI is offline   Reply With Quote
Old 01-05-2022, 11:15 AM   #10
Terry Cain
Terry Cain's Avatar
I would think a rule change would effect "all flattappet motors. Am I wrong to think that?
Terry Cain ???? STK
