Old 01-04-2022, 10:04 AM   #16
SSDiv6
Default Re: Throttle Limiters
Originally Posted by B Parker View Post
This was not a throttle limiter. I had a few friends about 35 years ago that would use this on a QJet. This would set your rpm you staged at. Hit the toggle switch and it would open your carb the same every run. For it to limit your throttle it would have to be on the other side of the linkage. BP
Barry,
In this particular case, the guy had it rigged to limit the throttle opening and got caught. It was directly hooked to the throttle lever with a modified bracket. NHRA Tech made him remove it and took it away.
