Old 12-31-2021, 04:06 PM   #31
e vassar
Liked 271 Times in 107 Posts
Default Re: Throttle Limiters
Originally Posted by GUMP View Post
What would happen if the NHRA policed all those restrictor plates, disconnected secondary mechanisms, and throttle travel restrictors, etc.?
. Darren.....do we have to run wide open?
Is Rich Christianson back????
Old 12-31-2021, 06:03 PM   #32
L.Fite
Liked 497 Times in 243 Posts
This is what happens when you let it become a bracket race...
If it's a qualified field, then some of this will stop.
Qualify 64 (65 if you have to have the first round bye)
I think the quotas are too low...
Look at Gainsville, full in 6 minutes? Come on man...
Excuse me, I shall now go and don my kevlar under pants and fire suit...
L.Fite is offline   Reply With Quote
Old 01-01-2022, 12:28 AM   #33
Frank Castros
Liked 2,739 Times in 966 Posts
Throttle limiters? Back in the day we were looking for throttle enhancers! Geez Louise. You guys need horsepower.
Old 01-02-2022, 09:43 AM   #34
Liked 10,780 Times in 2,241 Posts
This might be a simple solution to small I D spacers and gaskets: seal them up and the racer can’t change spacers or gaskets during the race. The racer will be able to change to the “ fast “ carb or throttle body but the marked spacers and gaskets have to remain in place.
Just some thoughts
Old 01-02-2022, 12:58 PM   #35
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
Just some thoughts
Larry, can we seal up the rear wheel nuts, I’ve seen a tenth between bias and radial tires. Let’s be fair on everything.
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
Old 01-02-2022, 04:33 PM   #36
I think anybody can Re-Tire any time they want. Sometimes I would love to Re-Tire with a 10.5 on the cars but its not in the rules. A few years back we could run a 12" DOT tire but NHRA changed the rule for stock.
Old 01-02-2022, 05:47 PM   #37
Herbie Null
I think the same should apply in all the ways we pick these cars up, tires, oil, ice down, weight, fuel, restrictor plates and engine, trans, differential heaters. You can’t just pick out one thing you don’t like, unless you seal the whole car up after Qualifying. We all have a game we play.
Herbie Null 201 SS
Old 01-02-2022, 05:58 PM   #38
Billy Nees
Liked 7,789 Times in 1,744 Posts
Like it or not, very true!
Billy Nees 1188 STK, SS
Old 01-03-2022, 08:56 AM   #39
If it is within the rules as written it’s ok.
Old 01-03-2022, 12:14 PM   #40
Robin Lawrence
Sponsor
Liked 715 Times in 120 Posts
Talking Re: Throttle Limiters
Daren,
I am going to un plug one injector. All good!!
Once they start looking at the injector wiring I will un pin in one of 2 connectors available at the ECU or at the connector for the main harness to injector harness.
Game ON!
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
