Old 12-28-2021, 01:44 PM   #51
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Default Re: Can We Un-ring The Bell
Originally Posted by Todd Hoven View Post
What is wrong with the blinders?
Because you can win with them and he can't. They could take it all away and still someone will look for an excuse as to why you win and they don't.
Old 12-28-2021, 01:53 PM   #52
Kyle Kohr
Liked 62 Times in 7 Posts
What I'd like to know is how many Racers are actually "spot-dropping" and how many are using their ignition box, grid and data logger to determine an exact time and distance on the track to "drop". Something that the system is perfectly capable of doing. Again, I'll say "It's the 21ST Century. I tend to doubt that many very successful Racers are picking a pole or flag to "drop" on.
Are you talking about spot dropping to keep their cars slower than a second under or spot dropping to hit their dial in?
If your talking about to hit your dial in I’d have to agree your tune up is way reliable unless blatantly cheating with the grid such as using an arc module or something similar. Just pulling timing at x seconds isn’t going to help if you lost a tenth at half track because the setup/tune up is bad. You’d need to have something that tells the grid your track position which is already illegal.
I would argue and say that successful racers are just in good consistent cars, not pushing rules with electronics.
Kyle Kohr is offline   Reply With Quote
Old 12-28-2021, 02:53 PM   #53
Kinda like deep staging, isn't it? ;-)
Old 12-28-2021, 03:13 PM   #54
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Is there anyone that is successfully spot-dropping on every run, or hitting the dial dead-on every time they do it?
Spot dropping is one tool in the bag of a complete top-end driver, and learning how much to hold and how to kill it is a learned and earned skill. The car also needs to be good first.
S/ST 51
S/C 53
Old 12-28-2021, 04:07 PM   #55
Frank Castros
I would venture to say that there are more good cars out there than great drivers.
Old 12-28-2021, 04:35 PM   #56
Lenny5160
Lenny5160's Avatar
I'd 100% agree. I'm mostly puzzled by a post that is worried about illegal drop spot identification, as if there are people killing it with the spot drop constantly. Unless one doesn't understand how/why it is utilized.
S/ST 51
S/C 53
Old 12-28-2021, 05:50 PM   #57
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Could someone please tell me the difference between electronic "traction control" or a light flywheel or a slipper clutch?
Dave Noll, EF/S ,?/SA 6526
Old 12-28-2021, 05:50 PM   #58
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
I think Billy was referring to if using a grid and a program to spot drop. The opposite of a .90 car on the other end. Wouldn't that be like using a throttle stop timer?
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 12-28-2021, 05:52 PM   #59
Barry Polley
Guest
Posts: n/a
Nothing. Every car was equipped with them from the factory. If not there -you do it on your visor. Nothing illegal about them. Nothing in the rule book that says; you cannot have them or have to see every bulb. Same with brake switches.
Old 12-28-2021, 06:03 PM   #60
Billy Nees
Liked 7,782 Times in 1,743 Posts
I fully understand how "spot dropping" works. I've spent the better part of my life in a slower-than-normal car.
What I am questioning is, can a "good" car be set up to use the data loggers timer (set up to start on WOT) and drive shaft sensor or wheel sensor to "turn on" something like a shift light at a certain point on the track to "alert" the driver to lift? I know that it's possible but is it practical? Ya know, kinda like a matty box but not exactly (is that a dirty term?). I have been around long enough to know that a couple of great drivers have been caught with them AND delay boxes.
Billy Nees 1188 STK, SS
