Liked 311 Times in 175 Posts
I built a similar truck almost 20 yrs ago and had several winning seasons. Things to consider..... trucks are nose heavy, so spend the effort up front, headers are a ton of work unless you opt for fender wells and sacrifice front tire size, pg trans works fine but you need a 198 1st gear. Also you need to spend the money for good double adj. front shocks. Hope this helps and good luck,.
