Old 12-08-2021, 10:18 AM   #11
Rob Wright
Liked 21 Times in 7 Posts
Default Re: LS Hydraulic lifter limitations
Originally Posted by Mark Lewis View Post
ON the short travel hydraulic roller lifters what is the best valve adjustment to get the best performance out of the lifter. Assuming not too much spring rate or valve train weight
I honestly cannot answer that. I followed the supplier's recommendations and it wasn't as good as a normal full travel lifter with plunger set half-way down.
Someone somewhere may have found a way to make this all work out but it was complex and risky enough for my situation to cause me to stop looking at it once I saw worse dynamics in an otherwise stable setup that would spin clean-clean to well above 8000 RPM.
Rob Wright is offline   Reply With Quote
Old 12-08-2021, 08:58 PM   #12
e vassar
Liked 271 Times in 107 Posts
Thanks everybody. To be honest..Ive never even had a valve cover off.
I will get it apart..see whats going on with rockers,springs,etc. check spring pressures and...probably ask for more help.
Rob,Darren .what should I do with the coils? Theyre still on the valve covers.
Old 12-08-2021, 09:58 PM   #13
GUMP
Liked 2,359 Times in 557 Posts
That's where I have all mine.
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
Old 12-09-2021, 09:20 AM   #14
Rob Wright
Unless you have a packaging concern I suggest you leave them on the covers.
I've heard some dreamed up "imagineered" reasons to move them but there really isn't any good functional reason why it would be better to put them anywhere besides where GM put them.
Old 12-09-2021, 04:26 PM   #15
Adger Smith
Liked 880 Times in 311 Posts
The best reason I can see to leave them where GM put them is the shortest possible plug wire with less chance to arc to something and with less voltage drop.
Adger Smith (Former SS)
Old 12-09-2021, 07:11 PM   #16
e vassar
Yes after further study under the hood,I think you guys are right. No big thing just unplug the harness and plug wires to remove valve covers. I need to stop trying to outthink those G.M.engineers.
Thanks again
Old 12-09-2021, 07:18 PM   #17
Albert Lee
Liked 258 Times in 49 Posts
It's an LS. Why would you have to take the valve covers off?
Al Corda
Albert Lee is offline   Reply With Quote
Old 12-09-2021, 11:46 PM   #18
GUMP
I don't have the budget for that!
Daren Poole-Adams
NHRA Stock/SS 2007
Old 03-11-2022, 12:03 PM   #19
e vassar
Originally Posted by Rob Wright View Post
Stock LS7 lifters have the best dynamic stability out of any I've tested, and the earlier-version LS7 lifters with circlip axle retention are the ones to have.
Differences in stability of stock vs aftermarket brand "M" and aftermarket brand "J" is not incredibly significant.....Best to worst (stability-wise) is listed in order and again, they are not vastly different. All of this assumes plunger at mid-travel for preload.
Actually in my experience the WORST performing hydraulics (stability, , on a given cam/spring/rocker/pushrod combination) were limited travel units.
If you're hitting a wall at 7000 RPM, you should look at whether you have TOO MUCH spring force (compressing the lifter plunger isn't necessarily the problem.....), too heavy retainer, spring, rocker, or all three, and more often than not the cam lobe geometry itself.
Proper lobe geometry shouldn't require tons of spring force to run well past 8K RPM if it is packaged with light valves (like stock LS) a light rocker (like the stock LS), retainer (again, stock LS), and spring (like beehive or well thought out dual like PSI LS 1512 ML), along with a pushrod that is stiff enough to avoid deflection/energy storage/energy release. This sequence causes bounce at closing and that's when stuff breaks.
Robin where is a good source for the PSI LS1512ML? What about a beehive?
Old 03-11-2022, 02:51 PM   #20
SSDiv6
Ken Juszczyk at Motorsports Unlimited
https://www.motorsportsunlimited.net/
or
Brian Benson at Dakota Parts Warehouse
http://dpwferreavalves.com/
