Old 12-01-2021, 10:43 PM   #16
Eman
Liked 133 Times in 76 Posts
Default Re: need help diagnosing brake issue
2) Since I've been swapping lines on the MC, I will thoroughly bleed the brakes again, then as mentioned, remove the lines at the caliper and cap them. Not sure what I will cap them with, but a short flare plug would be great as not to add a lot of air.
Not sure what type lines you have or how they attached to the caliper. If they have flared lines get a line union that fits the flare nut and a plug for the other side. If it's a banjo just use copper washers and a nut and bolt.
