Old 11-05-2021, 03:32 PM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Default Re: water pump circuit breaker pops
Originally Posted by Jeff Niceswanger View Post
I have a question. You come back from a run, lets say your in the semi finals. You know you have 20 minutes and they will be calling you back up to the lanes.Your 16 volt batteries are way low, and they are a constant worry (especially in a Fuel Injected engine), but your engine needs 40 degrees drug back out of it... If you can not run the pump while your charging, your not heading up the lands prepared. What it sounds like is all water pumps should have a 12 volt step down, right ?
I have a plug on my fan and pump. After a run I cool the car using a separate battery. Just unplug from the car harness and plug in to the harness on the separate battery. That way I can turn off the battery disconnect switch in the car to charge the battery and cool the car as needed. Works excellent
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 11-05-2021, 10:34 PM   #12
Dave Gantz
Liked 251 Times in 125 Posts
Ed Wright (Hasn't been on here for a while, a post on here said his health isn't good. Hey Ed?) posted here about a similar system. Sounds like a great idea.
Old 11-08-2021, 05:59 PM   #13
1legjerry
Liked 72 Times in 15 Posts
I think you will find all your 12 volt electronics will last longer if you don't run them when on the battery charger.
An alternator would help, You wouldn't need to worry about the ignition getting 16 volts while the engine is running.
Like other have said a step down resistor
A small 12 volt jump box to run just the pump and fans between rounds.
1legjerry is offline   Reply With Quote
