Old 11-04-2021, 02:20 AM   #21
GTX JOHN
Default Re: Performance Gain Stock Rockers to 1.5RR?
i would like to elaborate with some stories = but I
better not!
John Irving
741 Stock
741 Super Stock
Old 11-06-2021, 07:42 PM   #22
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Building the Pure Stock engine replaced the 3/8 with a 7/16th stud figuring it was a good bit stronger. Cannot remember the racers name he sent me his modified LT1 SA Stock Rockers. Bought new 7/16th ball, installed them and runs smooth.
Like Billy said, he saw no gain going to Rollers.
Many of our Impala Club members stayed with the Stock LT1 SA rockers installing the popular HotCam with no problems. Figuring the 3/8th Stud was not much of an issue to begin with.
Wondering if someone makes a 1.5 SA Roller Tip?
Use the 7/16th ball and trim the sides up to fit.
Would stop all side loading on the valve and guide.
I have set of original GM SA 1.6 Roller Rockers.
Then again they use 3/8 stud.
Saving them for a project.
Dan…PRW make 1.5 x 7/16 Self Aligning roller tip rockers. Part number is PRW 0835920. If you already have converted to 7/16 studs, why don't you just buy the proper guide plates and a decent set of Roller Rockers and be done with it. Eventually you will end up there anyways. Hope this helps. MB
MAURICE BLENDHEIM is offline   Reply With Quote
