#191 | |
Liked 48 Times in 44 Posts
The RA4 was factored to 380hp, so unless there was a special RA4 factor for just the 69 Firebird (not likely back then) I'd rule that one out. When I look at where the RA4 GTO's ran, their RA4 had to be factored to 380hp, maybe 385hp but no more than that, and Dwight S said 380hp on the other thread. So I'm still betting Ben Wolf was a really high factored RA2, or a Chevelle300 or Nova L72 car (1969 was the 1st year for auto trans for the L72). Just dont know. |
#192 |
Liked 32 Times in 27 Posts
DC....Its OK, I put it out. A guy had difficulty believing the L72 Camaro could be in SS/E.
In fact, its right on the line btwn SS/D and SS/E (7.56). When I pointed out the SS/C ZL1 was at 6.51..he started to realise how little separates the classes. As an additional ‘win’, I was able to show how the 396 68 Nova met SS/D in 68, but slipped to SS/E in 69.....due to weight break changes. I think a lot of people struggle with the concept of a 396 Nova racing an L72 Camaro....but the weight breaks don’t lie....just shows what a pig that L72 motor was! But seriously......your sheets are invaluable....good job!! Last edited by Rat Patrol; 11-04-2021 at 04:43 PM. |
#193 |
Liked 747 Times in 362 Posts
"...Dwight S said 380hp on the other thread..."
Maybe it was 380 at the beginning of the season, then increased later in the season. That could make it possible that a '69 Bird could have run C/SA at the Winter Nats, then B/SA at a later '69 season race. Maybe the Phil Monteith '69 Bird ran B/SA at either an AHRA or IHRA track. Or maybe that pic was taken in a later year. Or ? It's possible that not a single Pontiac combo ran NHRA B/SA, in '69. Not sure. Was a '69 RAIV Bird available early enuff in '68 to make some of the late season races ? Last edited by oldskool; 11-05-2021 at 04:45 AM. |
| Liked |
#194 | |
3300/385=8.57 or C/SA=8.50 in 1969 I think the RA4 was at 380hp all thru because there are RA4 cars in the wins/records from early 1969 thru late 1970 that all fit 380hp. So my bets for the Ben Wolf car: 69 Chevelle300 L72 69 Nova L72 67 Comet 427-4v 64 Belvedere MaxWedge Those all fit B/SA=8.00. I guess you could mistake those 4 cars for Pontiacs but it'd have to be pretty dark. |
#195 |
#196 |
"...Dwight said the RA2=385hp factored by NHRA...
I think the RA4 was at 380hp all thru because there are RA4 cars in the wins/records from early 1969 thru late 1970 that all fit 380hp..." I find that REAL interesting. WHY ? ![]() Because the '69 RA4 had the same cam, BUT, the RA4 used 1.65 ratio rockers, whereas the RA2 only had 1.5 rockers. This gave that engine more valve lift & more effective duration, which HAD to produce more power. THEREFORE, why would NHRA actually rate the RA2 engine higher ? Don't make any common sense. http://www.classracerinfo.com/Engine...3&MAKE=Pontiac http://www.classracerinfo.com/Engine...2&MAKE=Pontiac Don't think it actually increased power output, but the RA4 also had an alum intake. Seems that NHRA would have taken this into consideration & initially given the RA4 a slightly higher hp factor. or at the very least, the same as the RA2. Can't think of a single reason to rate the RA4 LESS than the RA2. The answer to WHY, would be very interesting to me. AND, after a few '69 Judge Stockers began setting records & winning class at some races, seems that NHRA would have taken another look at the RA4 engine & upped the hp factor. "...???? 1972..." Yeah, I think I posted a pic of Truman Fields running A/S @ the Summer Nats, in '72. So, that was a special year. Seems that Stock had sort of "Pure Stock" rules that year. I suppose the weight breaks were different, which caused Truman's Bird to run A/S. He even set an A/S record. http://classracer.com/classforum/showthread.php?t=51198 Then, '73 was the year Truman won Stock @ Indy, running C/S. Then, in '77, Mike McKinney won Stock @ Indy, running that same car, in B/S. Lots of rules changes back in those days. Pic #7 shows Truman running in D/S. Don't know what year that was. He ran '68 Birds with several different paint schemes. Pic #8 shows one of 'em, with B/S on it. Also have a pic of it that color, running C/S. Pic #9 shows a Burgundy color he ran, in D/S. So, these pics show Truman Birds in 3 color schemes & 4 different classes. He also moved several times, as noted by the different perm numbers. Last edited by oldskool; 11-07-2021 at 09:00 AM. |
| Liked |
#197 |
Well, the Wolfe car will have to remain a mystery - Ive put the RA2 in my web site....with a question mark.
I think the most likely thing we’ve uncovered is he was probably part of the Wolfe & McClelland team.....that does seem to make sense. Last edited by Rat Patrol; 11-07-2021 at 03:07 AM. |
#198 |
"...Ive put the RA2 in my web site....with a question mark..."
can't prove it was or wasn't Last edited by oldskool; 11-07-2021 at 09:22 AM. |
#199 |
OS - I figured going on available info- We have some confirmation of it being a Pontiac, and RA2 Firechicken is about the best fit....so happy to have it as a ‘possible’.
Now I have to re-visit some of the other info thats been raised and correct it. |
| Liked |
#200 |
DC - Was the 396/375hp Chevy motor re-factored in1968 to 425 hp? I seem to recall you saying it was?
