Re: water pump circuit breaker pops
Originally Posted by buzzinhalfdozen
you really should have the master battery switch off while charging, voltage can get pretty high while charging 16 volt batteries. other than that you could measure the amp draw of your pump, could have an issue with the pump motor but i'd lean more towards the charger being hooked up as your problem.
I never did Joe. I cooled the motor, ran the valves and never had any issues with 16 volts. But I had the car completely relayed. And I had a MSD suppressor/capacitor (MSD 8830) on both my Holley FI and MSD Grid's main power wiring.
Jeff Niceswanger 3740 SS
