#1 | ||
Liked 733 Times in 384 Posts
Stan |
Liked 747 Times in 362 Posts
Hey looks like I've already visited this subject.
Oh well, it seems that the same subjects keep coming up, over & over. They are argued about, then dropped, then later, somebody else will start another thread on exactly the same subject. I suppose it happens on all car forums. Some will say just "Do a search". But, I've found that on this site, it does absolutely no good to do a search. I've tried many times. Get mostly stuff that has absolutely nothing to do with the subject I'm lookin for. ![]() Just noticed that the '74 2-barrel 400 also can use 88.9cc heads, as well as the 1.25" venturi carb. So, it can have a bigger carb & more compression than the '74 350. MIGHT be a better combo ? But, would need a lower hp factor, than 255, to really be a good combo. http://www.classracerinfo.com/Engine...6&MAKE=Pontiac Last edited by oldskool; 10-07-2021 at 04:00 PM. |
Liked 5,109 Times in 1,947 Posts
1.18 carb is the same size as the 305s ..Some of them are under 180 hp. In U/SA , a Pontiac would have to weigh 600+ pounds more, in the same class.. No thanks..
I didn't even mention the 302 FFFFFFords. The big inch Pontiacs had a 1,250 carb, I believe. Same as the smog 350 Chevys. The 69-70 350 Chevys have the big 1.375 carb. That's the one that the restricted circle burners use. 69 Chev 350 2v is good. The 70 is even better... 70 4 dr. Nova should run low 12's in N/SA, with no roll bar , belts ,and monkey suit requirements.. One of the best 2V deals is of the blue oval persuasion, but is stick shift only, and we now know it's harder to win with that extra pedal. ;-)
