Liked 7,782 Times in 1,743 Posts
Liked 1,345 Times in 410 Posts
Removing 200lbs out of a small car seems pretty hard and ridiculous to do. Then you lose a 1/2 a second of index going from CF/S to BF/S for just 200lbs. Something don't add up in my math. I don't watch those classes. Did they add EF/S or something?
Paul Haszlauer |
BF: 16.00 to 17.49 18.99
CF: 17.50 to 18.99 19.00 to 21.99 DF: 19.00 to 22.00 to 24.99 |
They SHOULD have added a class or two between B and E!!!
Liked 302 Times in 73 Posts
I wish NHRA would buck up and explain why this change was made.. this will effectively force one of the nicest dudes on the West Coast to retire unfortunately..
Ya know, I've had more than one NHRA "Higher Up" ask me what they can do to make this stuff more affordable. I built a car that I need like I need another hole in my head to try and prove a point as to how affordable a FWD combo can be and how simple it can be to do. They should have added a couple of classes.
Other than the Tech people who are on the ground at a local level, there is no one in the NHRA that knows or cares what it is that we do. Just ignorant!
#7 | |
Liked 165 Times in 60 Posts
#8 | |
Billy, I'm wondering why myself....especially if there's no other changes? Moreover, I wonder if DF/S is going to continue to allow V6's (like they do now)? I look forward to hearing an explanation about this, because (I.M.N.S.H.O.), changes should be made to increase (not decrease), the number of FWD stockers in the country! Since this is happening, I wonder if the indexes are going to reflect this change as well. It's interesting that it only affects BF/S-EF/S and not AF/S or AAF/S????
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) Last edited by GarysZ24; 09-30-2021 at 10:38 PM. Reason: Felt the need to. |
I wonder about the "or something", because EF/S has been here for years. BIll, Stan, Brent, and Rob, amongst 1-2 others run that class. I agree with you also the math analysis.
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) |
Sorry Billy for sure. I just took a few minutes to look at Gary Hampton's combo .If I'm correct Gary you are rated at 125hp and did weight 2545lbs minimum in DF/S. Now you have to weight 2920lbs in DF/S. You need two friends to ride along with now to add 375lbs. But yet Bill O'Conner's slow roller Horizon didn't get effected one bit. Why would they basically kill some combinations.
Like you say Billy they need to add more classes. Which we probably have too many already. That or completely change all the hp ratings fairly on these cars and put these cars in T,U,V and W. That might be a crazy huge stretch but just thinking out loud. that or add X. Y and Z and let any amount of cylinders run in any class. Another senior moment. Paul Haszlauer |
