Old 09-22-2021, 06:51 PM   #11
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: Power Brakes and Vacuum
Does that work well with Disk Brakes?
Got this one in today
GM Genuine Parts 20804130 Power Brake Booster Auxiliary Pump Assembly
Have to figure how to mount it and get a Male Connector.
Dan
Yes it does work with both the OEM and aftermarket 4-wheel disc brakes.
The same pump is also used in Volvo's, Subaru's and other car models. The mount bracket for the Auxiliary Pump is GM P/N 25920516.
You can get the connector either at the dealership or NAPA.
This is an install video.
Old 09-22-2021, 09:09 PM   #12
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by Tex013 View Post
here is another pressure switch
https://www.amazon.com/dp/B078T5NL4S/ref
This is similar/same as what they use in the COMP and similar vacuum pumps If you want switched pump operation .
Tex
How would this attach?
Directly from the pump to the Booster?
Dan
Old 09-23-2021, 03:45 PM   #13
Dan Fahey
Dan Fahey's Avatar
Just bought this system from Master Power Brakes
100% complete and simple.
Well except finding right place to mount.
www.mpbrakes.com
Old 09-26-2021, 05:47 PM   #14
Tex013
Liked 44 Times in 26 Posts
Dan ,
switch goes in booster vacuum hose between pump/booster.
The kit you bought is just an easier package .
Good luck
Tex
Tex013 is offline   Reply With Quote
