Liked 755 Times in 213 Posts
Your right Sir,
I also saw the Neff and Mozeris F/DA that Kayla drive and it's also a very, very interesting setup. In that case, look like the complete block is there with a cover just over the passenger side deck. Could it be that, in this side bank, pistons are still there for balancing purpose ? Keep on SSDiv6, Last edited by Charles Stewart; 01-31-2025 at 06:12 PM. |
#2 | |
Ho, wow... A big "merci" to share that kind of information.
I really appreciate your comments. Thoses guys (in comp) are really amazing and always thinking further. Thank you once again for sharing... Charles Stewart |
Liked 239 Times in 94 Posts
I guess that is the way to handle the power with that combo. I recall a Mercruiser 4 banger Comp car several years ago with the stock die cast Mercruiser block and it was the weak link even with a lot of reinforcement.
Liked 1,112 Times in 304 Posts
Tom, I think you are thinking of the white roadster that ran K/A some years ago, and was raced by a guy from Saskatchewan Canada, named David Fromm (sp?). I believe that is the same car that Clint Neff still runs in K/AA.
I think that Michael Hanrraty used to run a Mercruiser 248 cu.in. 4 cylinders block a few years ago on his altered.
If my memory is right he is now using a different block today. Something like a CN block (half DRCE 2) or Rodeck ???But I'm really not 100% sure. |
Liked 174 Times in 39 Posts
I believe some of the K/A(A) cars are using a billet block made by Weston Machine that accepts a Pro Stock head. I'm not sure if there is just a GM version or one that accepts a Ford or Mopar head as well.
https://www.competitionplus.com/drag...ces-the-drc-iv
3207 D/SA, C/ED |
