Old 09-17-2021, 02:04 PM   #1
SG3001
SG3001's Avatar
Liked 2 Times in 2 Posts
Default Re: Trans Cert Tags
Recently had Division 3 Chassis Inspector at my shop to do chassis certs. I asked at that time about certs on a card instead of on the trans case. He said it was perfectly acceptable. The stickers looked like they would be voided if removed from the card. Mike Johnston 3001 Comp,Super Comp,Super Gas
SG3001 is offline   Reply With Quote
Old 09-19-2021, 09:24 AM   #2
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Thanks for the responses......
I emailed Cvengos this morning to get his take on it. I'm probably worrying over this too much.
SC 707Y
Dano is offline   Reply With Quote
Old 09-20-2021, 07:26 AM   #3
Dano
Dano's Avatar
Pat Cvengros
Sep 19, 2021, 9:22 AM (20 hours ago)
to me
Just have available for tech is fine.
SC 707Y
Old 09-21-2021, 11:44 AM   #4
Maverick
Liked 36 Times in 26 Posts
How much does it cost to have a trans case re-certified, and how long is it good good. Same question for transmission shield, how much and how long is it good for.
Old 09-21-2021, 12:07 PM   #5
Dano
Dano's Avatar
Recerts are good on case and shield for 5 years. An example of cost for recerts from Reed are about $100.00. Other costs are incurred tho....Costs for shipping to them and back and forth if not delivered/picked up by you. Will they need to have the trans emptied by a trans shop if not done by you? If so, that costs...etc. etc. etc.
The Hits Keep Coming
SC 707Y
Old 09-21-2021, 12:22 PM   #6
drgrcr1156
Liked 2 Times in 1 Post
This may be a good tread to ask this. Does the SFI trans case have to be recertified every 5 years? I am considering a new TH400 case instead of buying another carbon fiber shield. They will only recertify once. So the money will lessen the expense of a new case and bell housing with its added benefits.
drgrcr1156 is offline   Reply With Quote
Old 09-21-2021, 12:37 PM   #7
Dano
Dano's Avatar
Certs for Cases and Shields are only good for 5 years. You may want to weigh the expense of a TH400 SFI Case vs a Complete SFI PG if that will work in your car or in the future you decide to shelf the 400. May be happier and save more $$'s ultimately.
SC 707Y
