Liked 48 Times in 44 Posts
We cant figure this out on Fordfe.com
NHRA Blueprint .DOC files for 1968-69-70 say the 428CJ valve lift is .481 .490 ok But a footnote for each year shows an OPTIONAL 428CJ cam with lift .527 .527 I've read that Ford said the C8AX-C hydraulic cam was "optional", with lift of .500 .500 1.73 rockers or .509 .509 1.76 adjustable rockers AFAIK no 428CJ ever left the factory with that cam but several sources say it was NHRA Stock legal even back to 1968. But a cam with .527 .527 lift in STOCK class 428CJ Is this a typo (for all 3 years) or what? What are stock class 428CJ's running today as max lift? .509 or .527? thanks in advance |
#2 | |
Liked 166 Times in 46 Posts
#3 | |
Liked 1,603 Times in 583 Posts
In lieu of looking at the Ford Engine Blueprint specs, look at the bottom of the list and look at the Shelby specs. http://www.nhraracer.com/content/gen...634&zoneid=132 |
Liked 419 Times in 85 Posts
Its applicable to all 428 cobra jet engines. I had built a brand new 428 for my Torino over 20 years ago and this rule changed allowing the .527 camshaft. The addition of parts at that time in A-D cars was out of control. It was by no means brand specific. There have been many battles to take parts back but have only been successful taking parts from mopars.
#5 | |
So then 1. You're saying the .527 lift is a recent change, like in the last 20 years? 2. What cam IS that? It must refer to an OEM grind, right? 3. The only OEM cam I know of even close to .527 lift is the SOLID 306-306 duration cam used in 352HP 1960 390HP 1961-62 406 1962-63 427 1963-67 428PI 1966 only That had .298 lobe lift which is .524 gross at 1.76 rocker. Is THAT the .527 lift "OEM FoMoCo" cam? Or some other cam? Solid or Hyd? Which do you run? Can of worms indeed. |
#6 | |
Liked 7,800 Times in 1,747 Posts
And cowl hoods on 69 Camaros! And 1.21 2V carbs on 302 FFFords other than 82 5.0 stick only! I'm glad that I race Aardvarks!
#7 | |
https://www.428cobrajet.org/id-cam ...just waiting for the letter that says the C8AX-6250-D camshaft, with 0.600"/0.0600" lift and 330 duration (273°/273° @ 0.050"), 107 LSA is also legal... ![]() Last edited by SSDiv6; 09-16-2021 at 05:48 PM. |
#8 | |
"Ford described this cam as ".515 lift-steel-use on hydraulic lifter engines". I dont recall seeing the .515 before but it's in the link you gave. The most legit info from the era I have is is in March 1968 issue of ShopTips (cant attach a PDF here) which is either on 428cobrajet.org or Mustangtek. It refers to the C8AX-C cam as "production" (LOL) with .500 at 1.73 rocker lift or 509 at 1.76 rocker lift The same issue lists the 1968 NHRA classes, and running the 428CJ in either C/S=9.00 class or SS/E=8.70 class, which implies the 360hp factoring was already up to date. That much I think we all get: The C8AX-C cam is not known to ever have left the assembly line (at least not under the hood) but it was legal for NHRA Stock at .509 .509 lift I'm still thinking that .527 lift as now listed in the NHRA blueprints is some kind of a garbled number, either from mixing up .289 lobe lift (C8AX-C hydraulic) with .298 lobe lift (427 SOLID cam). .298 lobe lift gives .515 valve at 1.73 rocker (same as the strange text on 428cobrajet.org) or .524 valve at 1.76 rocker. If there's actually a 428CJ-Legal cam with that lift, that's what I was hunting for. EDIT: I found the strange .515 lift for C8AX-6250-C. Here is the page from 1965-72 MPC Master Parts Catalog showing it. I think the .515 number here is an error, but the point is, it's THERE, so could be easy for it to propagate into a "Blueprint". Still, .515 (assuming 1.73 rockers) is only .524 with 1.76 rockers, not .527. But at least we know the source of the .515 number. Last edited by DeuceCoupe; 09-16-2021 at 10:55 PM. |
#9 | |
Liked 225 Times in 136 Posts
From what I experienced is that the 62 406 never used the 306 deg cam in production. My 62 496 was a late June production car and it had the 276 degree cam. I had a insider at Ford get me a production 306 but that was not till late July of 62. He did get me a SK version in late June!
#10 | |
https://www.fordfe.com/c8ax-6250-d-r...s-t164022.html |
