Old 09-05-2021, 12:06 PM   #1
marvstrick
Liked 33 Times in 10 Posts
Question HP
How much hp will 80 lbs oil pressure rob in stock 305 gm stocker
marvstrick is offline   Reply With Quote
Old 09-05-2021, 04:54 PM   #2
GTX JOHN
Default Re: HP
What weigh oil?
If 5/20 my guess is about 5 to 6 over 50 or 60
in my small block Mopar
Your combo should be similar.
Heavier oil would make more difference.
John Irving
741 Stock
741 Super Stock
Old 09-06-2021, 09:20 AM   #3
nolongerracing
Liked 72 Times in 27 Posts
Default Re: HP
Zero... been there done that
nolongerracing is offline   Reply With Quote
Old 09-06-2021, 09:47 AM   #4
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Default Re: HP
What is the controlling factor limiting you to 80 psi? Is it your engines clearances or the pump relief spring? If the pump relief spring how much extra oil are you pumping?
Stan
Stan Weiss is online now   Reply With Quote
Old 09-06-2021, 10:17 AM   #5
Signman
Liked 269 Times in 99 Posts
Default Re: HP
Did a lot of work with oil control and oil pumps on SBC.
Although did not back to back oil pumps (it's a PIA) did do so with filters making back to back runs on the dyno.
Replacing WIX racing filter with screen type filter lowered oil pressure gained 3-4 HP. Even though the paper filter "average" opening is 65 microns a 30 micron medical grade stainless steel screen released power.
Low load low drag oil pump screened filter effective windage control and what ever crankcase vacuum you can build legally will release power.
Old 09-06-2021, 07:29 PM   #6
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Default Re: HP
While on Dave Layers dyno several years ago we broke off the oil pump pickup. Had around 3 psi for the entire pull as it went unnoticed. Yes Dave was red faced about it. I always believed in Amsoil after that. As the bearings looked absolutely brand new afterwards. There was 4 to 5 difference in the previous pull and the one without the pump pulling against the engine .. So if your cutting it from 80 to 50'ish I don't know, but less that that ....,,,,
Jeff Niceswanger 3740 SS
Old 09-06-2021, 08:45 PM   #7
MR DERBY CITY
Liked 8,052 Times in 1,529 Posts
Default Re:
A very respected engine builder was making Dyno pulls on a customers 305 stocker motor. At the end of the day they drained all the oil out and made a pull. It was 8 HP better. The names are intentionally withheld to protect the innocent….
Old 09-06-2021, 11:15 PM   #8
GUMP
Liked 2,355 Times in 554 Posts
Default Re: HP
Some........but, we don't race dynos....
Old 09-08-2021, 09:18 AM   #9
Signman
Default Re: HP
If you have chased the large HP gains and now searching the small gains consider this:
Low load, low volume, pressure recovery oil pump with micro polished pump gears and screen oil filter does reduce load plus will help flow, reduce cavitation and free up HP. All positives don't know the real gain but do know a prestigious stock engine builder did the tests years ago and was modifying oil pumps on his engines. Was tutored by a former stock engine builder who had a fixture to test oil pumps and oil 30 years ago. You probably know getting the oil level as far away from the crank as possible will show a large gain.
Consider this: Any engine with distributor driven at the back of the cam load on that gear driving the oil pump AND distributor should see reduced loading/unloading from the bypass open/close plus overall load will be less. Do ya think would make timing more accurate plus contribute less to valve train harmonics for gains in a couple more areas??
Old 09-08-2021, 05:30 PM   #10
Lee Valentine
Liked 319 Times in 68 Posts
Default Re: HP
In the days of heavy oil,10w40 saw 10 horsepower with hollow filter.
Lee Valentine 1661 STK
