Old 08-22-2021, 03:09 PM   #1
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Micro Welding of bearing shell to rod housing bore
2.375 crank pin, 5W30 oil, close to .003 vertical bearing clearance, bore is round within .0002, stretch gage.
I'm not understanding how to check housing bore diameter with the bearing installed.
Thanks
The bearing has a thickness specification that can help you determine the amount of crush you are getting after you torque the rod. How many use cycles do you have on the bolts and what type of bolt are you using?
Old 08-22-2021, 03:40 PM   #2
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
OK, I have no personal experience with this problem. But have talked with someone who I believe had a similar problem. He modified his rod bearings to give a little more clearance in just that area and that seemed to fix his problem.
Stan
Old 08-22-2021, 05:10 PM   #3
dragracerray
dragracerray's Avatar
Liked 209 Times in 90 Posts
I have never had this problem. A long shot. Do you have your negative cable attached directly to the block? Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 08-22-2021, 07:25 PM   #4
Liked 10,714 Times in 2,230 Posts
Yes Ray the cable is connected to the block. I never considered an arcing or plating situation
Not sure on cycles on rods or bolts. Bolts are ARP 7/16 20NF 12 point. The big end of the rod stays rounder longer since we installed a clean neutral valve body in the trans. I use the brakes to stop the car without compression braking.
Old 08-23-2021, 01:25 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Larry,
The design of the bearing is important. The size of the rod bore determines crush. You may need a bearing with more ellipse or a slightly thicker oil for the .003 clearance.
It is a long read, but Mahle has a good read on bearings.
All bearings are not created equal!
https://www.speedperf6rmanc3.com/con...20Bearings.pdf
Adger Smith (Former SS)
Old 08-23-2021, 09:59 AM   #6
Thanks. I will read it
Old 08-23-2021, 12:04 PM   #7
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Which Manley rod and which arp bolt ?
