Old 08-22-2021, 12:35 PM   #7
SSDiv6
Liked 1,580 Times in 582 Posts
Default Re: Micro Welding of bearing shell to rod housing bore
How much clearance are you running and what oil weight?
Race bearings usually have additional crush built in them. Are you using a torque wrench or a bolt stretch gauge values? Make sure the main bore is round and check the size without and with the bearing installed.
This is a method used to check crush.
