Liked 11 Times in 4 Posts
I also apologize I should have posted in the Tech forum.. Sorry guys.
Liked 242 Times in 81 Posts
The low compression 340 in an E body has a very favorable Hp rating. Thank you Mike Loge.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
Liked 209 Times in 90 Posts
Dirtmod welcome to this site. I am not a Mopar guy but I will try to start you off. To run SS in a GT class first you need to pick the engine you want to run. Use this as a reference to pick engine size and Mopar horsepower rating.
http://nhraracer.com/content/general...634&zoneid=132 Once you pick an engine this site tell you what head casting and carburetor you must run in SS. This site will also tell you the minimum head volume CC, valve size, deck clearance/head gasket thickness, if piston is flat or domed. You are not necessary forced to run a Mopar block. Depending on the engine you pick there could be an aftermarket block you could use. Look here to find NHRA approved parts you can use. https://www.nhraracer.com/Files/Tech...edProducts.pdf You are not forced to use the Mopar intake in SS. You can use an aftermarket intake. These guys have been very helpful to me. I would identify your location as GTX John said. Local people can give you more dedicated help. I would also suggest you ask 1 or 2 questions per post so you don't overwelm people that want to help. Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
Thank you Ray, I'm in North Carolina. After doing some research, and the 1971 383 having a factored HP at 300hp, Looks like with my take on a novice calculation seems SS/I works? Seems like this car may be a better candidate for a regular SS class maybe not the GT. I think so far.. Lol Thanks, again.
Liked 3,184 Times in 973 Posts
Go to this site and request access from Dwight, great resource that many of us rely on….
classracerinfo.com
Dirtmod I am not familiar with the SSGT stuff to advise you very well. It looks like the 383 can not be used in SS or SSGT in a 1973 Barracuda. When you go here,
http://nhraracer.com/content/general...635&zoneid=132 None of the GT listing show the 383. Mopar and SSGT guys please chime in. Ray
Liked 883 Times in 237 Posts
One thing that's been overlooked in the conversation is since you have only a 8 point roll bar ,you are limited to to a combination that falls into SSGT/E or F ,and then only if you run the index . Even dropping to a lower class will need a cage if you run under the index.
Most viable combinations that can fit the car most likely will need a roll cage . Before jumping into the "shark pool" ,visit a Lucas Oil Divisional race and seek out some racers that are running Mopars in SS . Most will at least tell you what may not be a good combo and more than a few will at least steer you in the right direction.
