Liked 99 Times in 60 Posts
When converting a factory stock truck to a drag race truck, it is necessary to turn all bolts anti-clockwise. Later, after modifying each piece, bolts can be turned clockwise.
Larry Woodfin 471W |
Jake, it is a footbrake [bottom bulb] bracket racer.
Liked 284 Times in 87 Posts
'Singer... Are the rear tires like a 29.5 x 11.5 or 14 x 32? MB
Maurice, 29.5 x 11. The wheels and tires pictured are for mockup, and I will likely run a radial in the 29.5 x 11 range. The bias tires pictured are new but several years old. I might run the bias for a few test outings.
A few updated photos.
When the frame mods are complete, all will be braced and triangulated as needed. Another cross-member will accommodate the shocks, and the Antiroll bar will be in front of the diff.
