Liked 210 Times in 91 Posts
I am changing classes and need to add 100lb (ug). I will use 2, 1/2" bolts with welded nuts per the rules,
Is it legal -to add ballast in the passenger compartment? -to add ballast under the car? -to add ballast in the trunk? thanks in advance, Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
Liked 312 Times in 175 Posts
All are legal, provided proper mounting. Try over top of rear as first choice.
Liked 1,604 Times in 583 Posts
Liked 10,820 Times in 2,249 Posts
Look in class rules and general regulations in the rule book on how to add weight safely. All so talk to tech and ask if there are places where adding weight is not allowed.
Liked 93 Times in 52 Posts
Would it be legal to add it to the rear axle housing vs inside the car?
Guess you could make the axle tubes out of thicker material.
Liked 706 Times in 283 Posts
No Prep car bolt weight to axle to not upset sprung weight.
Liked 239 Times in 114 Posts
Try and minimize unsprung weight, keep the weight up in the body . I think the rules say that added weight can't be higher than the wheel wells . Adding weight to the axle will slow the axle reaction down , the lighter the better !
General Regulations Section 21, page 19
General Regulations Requirements) is permitted. Removable weight must be securely mounted to the frame or frame structure by a minimum of two 1/2-inch-diameter steel bolts per 100 pounds, or one 3/8-inch steel bolt per 5 pounds; all other weight bars, pucks, etc. must use minimum 1/2-inch-diameter SAE grade 8 bolts for attachment. Hose clamps, wire, strapping, tape, tie wraps, etc. for securing weight or ballast prohibited. Acceptable forms of ballast are 1) Heavier gauge steel floors (i.e., 16- or 18-gauge, heavier gauge and/or plate steel prohibited); 2) Frame reinforcing cross members; or 3) the addition of protective equipment such as roll bars, flywheel shield, etc. If additional ballast is needed and is permitted by Class Requirements, it must be permanently attached to frame, bolted with two 1/2-inch-diameter bolts per 100 pounds, with nuts welded to bolts. Maximum amount of removable and/or permanent ballast, unless otherwise stated under Class Requirements, is 500 pounds. Cars running 8.49 and quicker are limited to 250 pounds maximum, per SFI chassis specification. |
Banned
Liked 179 Times in 89 Posts
My suggestion would be if you have access to 4 corner scales see which corner of the car needs the weight.
