Liked 880 Times in 311 Posts
What He said ^^^
Inspect the pattern on the ground and the tire.... Always test...
Adger Smith (Former SS) |
Liked 138 Times in 51 Posts
You can usually run a little more air pressure with wider rims, which helps stability and sidewall life while maintaining a good contact patch. (i.e.: 9" slicks on 10" rims.)
LOCOMOTION Racing |
Liked 91 Times in 51 Posts
How hard is it hitting the tire? Do you have a slomo video?
Clark |
Liked 411 Times in 87 Posts
I had to run my super stock radials at 9lbs this past weekend and everyone thought I was nuts, truck wobbles all over at the end of the track with 1lb too much, I agree every ride is different. John
#5 | |
Liked 1,342 Times in 409 Posts
Again just a thought. Paul Haszlauer |
Thanks Paul I heard the same thing and will check that out as well, I can handle some wobble but third run Saturday even scared me, lol I set the record years back in Boise and the guy next to me said I was crazy.
Liked 902 Times in 237 Posts
To get rid of Radial wobble tighten up rear shocks problem solved
Don Kennedy 7701 SS |
