The plugs are showing signs thanks fo your help probably going to run no stop until I get some o2 s going to call some carb guys this week that do carbs for stop racing don’t know if I will get anywhere then send me your carb or I can sell you one I’d like to put a stunner 1050 on it but not buying one now
#2 | |
Liked 888 Times in 239 Posts
Very good people to talk to, and they really do know throttle stop carbs.
Liked 192 Times in 83 Posts
I'm running a 1250 by DC Carbs on my 565, but I have a bit more HP than you, and my car is almost 1000 lbs lighter than yours.. I just don't have Tom's compression at 14.5 to 1.. on the stop my O2's get to about 13.9 to 14.1 or so.. I also changed from VP C-14+ to VP X-14 with positive results... no tuning changes, and picked up 1 MPH..
I have also been told by many that 1250 is un-necessary on my combination, and that a 1050 or 1150 would probably work better.. next test and tune, I'm going to back to back my 1250 with the renovated 1150 from my 522 motor.. bigger isn't always better, but some carb builders go by HP numbers.. at 1004 HP, I would say that 1250 is not for you, especially at 3000 lbs.. Running lean while on the stop is kinda the norm, but if you're banging bearings, and possibly hurting the crank, I'm not thinking that running lean for 2 to 3 seconds is your problem.. but that's just me.. |
