Liked 19 Times in 9 Posts
How is that done, and where?
The best would be to purchase a new gear set already heat treated from Mark Williams, Indy Gear or Gleason.
I do not recommend heat treating any used set of ring and gears. If they are used, Cryogenics and REM/Micronite finish. http://www.performancemetal.net https://www.crownracegears.com/heat_treatment.html https://www.300below.com/motorsports/ https://negearpolishing.com/services/rear-axles |
Liked 783 Times in 195 Posts
Don't forget Tom's Differentials. www.tomsdifferentials.com
Liked 28 Times in 15 Posts
I have good results from Microblue in Denver NC Have several hundred runs on a Dana 44 and it looks like new.
Thanks for the input on this. The ring and pinion are new, but a discontinued ratio that is no longer available.
Tom,
Depending on the brand and supplier, it could be already heat treated. |
