Liked 140 Times in 51 Posts
Barry
Thanks for that tip,I went on there site and they don't make anything like that for the Chevelle,appreciate the input. Adger That was my first choice for a pan when Dad started this project however he put a Gen-6 block in and that pan wont fit and I couldn't find any stock appearing pans for this engine. Went with the Jegs (Made in USA) and was pleased with the pan but the fit needs some tweaking. I ordered the Energy suspension mounts and a new stock replacement idler arm to see if I can find any wiggle room. Thanks for the inputs,appreciate it.
The more people I meet the more I like my dog Kevin |
Liked 46 Times in 29 Posts
Problem I found w my 1970 Chevelle was the oil pan laying in the front tip of cross member and lightly on center link. The inner tie rods also hit.
I’m not sure if you have these issues or if this is a class car or a street/strip car. The energy suspensions come w a plate like their transmission mounts. So it effectively raises it an 1/8” approximately. Hopefully you get your dads car right. |
Liked 880 Times in 311 Posts
Kevin,
I'm sorry I went brain dead. I knew that and we had discussed all that. I'm slipping.. lol!
Adger Smith (Former SS) |
Adger
Anytime someone with your experience takes the time to share it,well I just appreciate it. Stay safe but above all have fun
Guest
Posts: n/a
Maurice, sent you a message with vender info.
Update
First thanks to all my friends on here,sure do appreciate the input. I installed Energy Suspension # 3.1117G motor mounts on both sides and they are just over 1/8 higher (on the bench not compressed) over new stock rubber mounts. I then shimmed them another 1/8 .This really helped. I then loosened the idler arm and tilted it down as much as it would. Lastly I removed the grease fitting and installed a flush plug in both inner tie rods. The steering will just kiss the pan on a full lock turn. So told Dad,leave yourself lots of room in a parking lot. LOL Thanks again
