Old 05-02-2021, 02:25 PM   #1
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Question Chevelle Steering Linkgage hits oil pan
I have a 68 Chevelle BBC with a Jegs 6 quart pan. The pan is similar to a Hamburgers/B&B etc. The steering linkage touches the pan when turning. I seemed to remember a post and there was a different idler arm some used but I cant seem to find it.
Thanks in advance for any suggestions.
The more people I meet the more I like my dog
Kevin
Old 05-02-2021, 04:28 PM   #2
prostockpete1
Liked 90 Times in 52 Posts
Default Re: Chevelle Steering Linkgage hits oil pan
how much clearance do you need ? maybe shim the motor mounts up a bit
prostockpete1 is offline   Reply With Quote
Old 05-02-2021, 07:30 PM   #3
SSGN
SSGN's Avatar
Lightbulb Re: Chevelle Steering Linkgage hits oil pan
I installed new made in USA stock mounts but I am thinking maybe energy suspension mounts might help. Does anyone know how much higher the engine would sit with a eurothane mount?
Kevin
Old 05-03-2021, 12:46 AM   #4
Eman
Liked 133 Times in 76 Posts
GM trucks with a 5.7L motor used a metal shim between the engine block and the mount. This might work to get clearance if the bolt pattern is the same for a BBC. I've also use Speedway circle track motor mounts as a shim. Moroso made short and long solid mounts for some vehicles. I have the sam problem on my Camaro and can't use a pan with the deeper frt. section.
Old 05-03-2021, 09:56 AM   #5
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I have energy suspension mounts.
They are just a little taller than stock rubber.
I still had to notch my pan for cross member and inner tie rods.
I have milodon 31187.
About 2 1/4” center bolt hole to mounting pad for block.
This is a factory big block car.
chris ok is offline   Reply With Quote
Old 05-03-2021, 11:12 AM   #6
Barry Polley
Guest
Posts: n/a
Rare Parts makes a longer idler and pitman arm, moves link forward approximately .250.
RP20526 pitman
RP20227 idler
These fit my 69 Camaro, might be diff for the chevelle.
Will change geometry also.
