Go Back   CLASS RACER FORUM > .90 Heads Up Class Associations > Mid Atlantic .90 Association
Old 04-16-2021, 10:57 AM   #1
BKSG1198
BKSG1198's Avatar
Liked 1,309 Times in 399 Posts
Default Info for Race # 1 & 2 at Maple Grove
Friday, May 21st - Test & Tune info for Maple Grove:
Gates will open at 8am
T&T will go from 10am to 4pm
Cost: $55.00
Crew: $10.00
Lanes will close at 3:45pm to run out the remaining cars left and lanes will reopen at 4pm till 9:30 for the Johns 625 Automotive Friday T&T. Cost for that is $25 but, you’ll be mixed in with Street cars also.
It is encouraged that even if your not running the T&T that day to park and go through tech.
Saturday, May 22nd, 2021
Gates will open at 7am
First call to the lanes will be between 8:15 and 8:30
Plan is to be sending cars down the track by 8:45am
Cost: $100.00 paid to Rob K. / $30.00 at Gate
Crew: $15.00 Crew
2 qualifiers (Possibly 1 TT if car counts are too much) and followed by eliminations
Classes contested - SST, SG, SC, TD & TS
Sunday, May 23rd, 2021
First call to the lanes will be at 8:45am
Plan is to be sending cars down the track by 9am
Cost: $80.00 paid to Rob K. / $30.00 at Gate
Crew: $15.00 Crew
1 qualifiers and eliminations
Questions or comments - Rob K 856-332-2851
Please see parking map below:
Here is a layout of the parking situation for the Lucas Race the following weekend of Memorial Day weekend. For the May 21st to 23rd .90 race and TS/TD event you can park wherever you would like but, once the event is over you MUST MOVE YOUR trailer out of the designated spots unless you are one of those designated classes or sponsors and park them into a spot labeled “OPEN”. If you are in one of the spots labeled for a specific class and not one of them your rig will be moved at your expense. The D1 event typically gets 500-600 cars so there will be no “saving spots” for friends who are not in attendance. All tape, beach chairs, banners will be removed from anyone’s trailer if you have more then the one spot next to the trailer allotted for you. We do understand some of you have more then one car so please make sure you plan accordingly with your neighbors and who will park next to you to give you enough room. There will be no saving a city block for all your buddies who can’t be at the event. You must remember we are doing this as a favor to you the racers by allowing you to leave your rigs at the track, we could easily have you go stack outside the gate or make you all drive home but, that would not be fair, so please don’t abuse this!
Comp will go in the upper area above the wall and overflow into the TS / TD area. (Blue)
PC Richard goes on the second row in TS and ideally has 4 spots saved because they are the title sponsor. (Green says PC)
TAD/TAFC – Fuel Island Row and the Asphalt row in front of that. (Red)
Sponsor rows – Grass behind TAD/TAFC, leftover TAD/TAFC Spots (Purple), Pumphouse row in middle of lower pits, Tree row below pumphouse row (Spots normally for Ken & Jeff K park).
