Liked 52 Times in 32 Posts
Just my opinion......leave the SST index and weight alone. limit to real cars with doors. As NHRA has spun the class as "entry level", the MPH should also be governed. Maybe a limit on MPH. It should also be included at all National events.
SC 707Y |
Liked 431 Times in 224 Posts
I don't understand what positive difference would come from lowering the indexes. The launch will be the same. The car will feel the same when it goes wide open and through the finish line. Is a couple more seconds of coast really what is wrong with the classes?
It would surely drive a lot of cars out that can't go 1 second under. I can't see lower indexes spurring anyone to go Super-class racing that isn't already doing it. If it does, it surely isn't enough to replace the racers who are driven out. What's the goal of making the move?
S/ST 51 S/C 53 |
Liked 1,877 Times in 577 Posts
If they were going to change anything it should be the tree
go back to a true 400 and a true 500
#4 | |
Liked 358 Times in 103 Posts
That should not happen and I understand it was stopped, however I think it was the cause of many red lights. Just tell us what the rules are and we can adjust. My 2 Cents Rick Cates Canyon, TX |
#5 | |
Liked 134 Times in 70 Posts
I'll add to that with. We would run a Divisional with a true .400 for SG & SC and a true .500 in SST back around 07 and 08. Then you go to a National Event and you're 30 slow. Nobody told you ****. There were a bunch of people in all the Super classes that didn't have the numbers to pull out but nobody ever got an explanation why.
Liked 126 Times in 61 Posts
I still firmly believe it was all about Angel crying on TV that she fouled. I went to a double division race and beat myself up all weekend not being able to hit the number. I found out the following week from a tech guy at the local track that NHRA changed the tree. Thats when I went to SSrt for many years till I had enough power to hit the .370 and moved back to SG
