Old 03-28-2021, 03:18 AM   #11
Dickens
Liked 12 Times in 8 Posts
Default Re: 2002 F body brake pressure
Originally Posted by Tom Meyer View Post
Rear brakes are on the front of the master and the pressure is taken at the bleeder on the rear caliper. The car when we got it had braided hose, we switched it to hard line. The car has good pedal and stopping it is no problem. Tom
Tom My car was plumbed backwards initially causing excess pressure on the rear brakes. I bent the backing plates before I changed the lines around. Mine has front disc with drum rear. Hard to find good help
Dickens is offline   Reply With Quote
Old 03-28-2021, 08:09 PM   #12
Tom Meyer
Liked 354 Times in 120 Posts
Thanks for all the help. Tom
Tom Meyer 5240 SS Stock ???
Old 03-29-2021, 11:17 AM   #13
Mike Mans
Liked 299 Times in 48 Posts
When we ran an automatic, we had dual rear caliper Mark Williams brakes (and MW in front as well) and would put about 750psi of brake pressure (on a gauge in the car) - and that would hold 43-4500rpm without issue. On the 2-step the car wouldn't move at all either in the front or the rear no matter how loose we had the front or rear shocks. The brakes held the car rock solid. I'm not sure about the master cylinder, but I assume it was whatever Mike Pustelny from MPR Race Cars would suggest.
Mike Mans is offline   Reply With Quote
Old 03-29-2021, 10:32 PM   #14
Eman
Liked 133 Times in 76 Posts
Was it a step bore master cylinder? If the master cylinder has the same size bore for both sections how can it have more pressure at one port? Did you measure the frt. and back pressure with a gauge?
Eman is online now   Reply With Quote
