Liked 482 Times in 159 Posts
The 462 and 461 combustion chambers are NOT identical. 461 heads have a rather unique combustion chamber shape as compared to all the other 1960's - '70's era hi-perf SBC heads.
Liked 705 Times in 219 Posts
Alright, I have a 3782461 head that someone told me was a 461X casting. I don't see an X on it anywhere near the casting numbers, I remembered seeing 461X heads that had the X at the end of the casting number. This head has a date code of G 111, but it does have a small X on the bottom of the head right below the water passage near the deck surface and between the intake gasket surface at the water crossover passage. It has 1.940 intakes, 1.500 exhausts, and looks like an original old head that might never have been apart. Where was the X that designated this as a 461X casting?
Seems like the 461 head is only legal up to about 1966 cars, the 462 head is legal from '61 to 68, the 041 head is legal from '61 to '70, since most new stocker projects are newer than that, the 041 head from '69-70 would be a better head to get, since it has a far broader range of applications. It's like the 993 casting for the '70's cars. Legal replacement for a lot of cars, for sure.
#4 | |
Liked 799 Times in 236 Posts
"That'll never work....." |
#5 | |
Liked 127 Times in 49 Posts
350/300 - 3917291,3927186,3947041,3991492,3767462,3890462,39 17292
Bobby Lundholm 3516 G/SA |
Liked 33 Times in 17 Posts
After Lee Shepherd "discovered" these heads, the race was on to find a pair, especially if you raced in the Super Modified classes as well as the Econo dragster/altered classes.
#7 | |
Liked 166 Times in 46 Posts
Liked 684 Times in 289 Posts
Like this...
That's it!! Thanks for the picture. Anybody have use for this head? I only have one.
