Originally Posted by Cbrinson47
Did you know that the factory tolerance on a micrometer, Dial indicator, or dial caliper is plus or minus .001. I know this because I used to calibrate precision tools for the Dept. of the Navy. They should be checked with "GAGE BLOCKS" a least once a year. Tools being treated to rough treatment as in running all over the U.S. should be certified at least several times a year. Do you really think most tools being used by the NHRA tech. dept. have been certified?
Not only that, but if one of them is dropped it needs to be set aside and sent in to be checked / calibrated.
Stan
