#21 |
Liked 13 Times in 7 Posts
Never liked the turbo action and how it slides from Neutral into 1st for T-400 reverse application. You never really know if it's truly in first where it should be, whereas a ratchet is in or its not.
N/A |
#22 |
Liked 253 Times in 95 Posts
I know for the 727/904 shifter they offer two gates. One has a positive stop for first. The other, like you stated, can be used with an air shifter. I agree, you have to be careful with that gate. The other one is nearly fool proof when manually shifting.
George Mirza D/SA 1236 ‘71 Duster 340 |
#23 |
Liked 280 Times in 139 Posts
If you ran a glide you couldn't beat a Perry shifter...gsa612
#24 |
Liked 46 Times in 29 Posts
B&M Quick Silver. Forward or reverse pattern.
NHRA and IHRA approved. Using mine 20 years. Just changed cable once. It fell on exhaust. My fault. |
#25 | |
Liked 24 Times in 12 Posts
![]() PS, The BBB is cool but out of my pay grade. |
#26 | |
Liked 800 Times in 237 Posts
"That'll never work....." |
#27 | |
Liked 888 Times in 239 Posts
Although the prices might be slightly higher and you'll pay shipping ,at least you can get the part. I've had to go this route with a lot of parts in the past year.
#28 |
Liked 132 Times in 52 Posts
I'm also a fan of B&M pro ratchet.
Terry |
#29 |
Liked 133 Times in 76 Posts
With a forward pattern 3 spd I've messed up the squeezing the lever, the worst is when you ease off the lever and end up pushing it to neutral. I've used the B&M Pro Ratchet and it's a great shifter. Turbo Action is good and does away with squeezing the lever.
#30 | |
Liked 129 Times in 53 Posts
Stop global whining |
