Old 03-12-2021, 10:49 PM   #1
Dave Toce
Default Advanced Clutches Single 10"
Advanced Clutches / Rob Youngblood 10" sintered iron clutch, flywheel, disc and pressure plate. Very little use the disc has an average thickness of .310". 350 lbs starting base. 18 Hemi Spline disc, chevy bolt pattern neutral balance 168 tooth flywheel. $1,100.
See add for photo
https://www.racingjunk.com/Clutches/...ingle-10-.html
Dave Toce is offline   Reply With Quote
Old 03-13-2021, 03:13 PM   #2
Dave Toce
Default Re: Advanced Clutches Single 10"
Sold Thank you Class Racer
