Liked 799 Times in 236 Posts
Not a real tech-y question but here it is.
Removed a bunch of decals and now have to deal with the old, nasty adhesive residue left behind. Goo Gone worked ok on the softer residue..not so good on the harder residue. Same with WD40. Any experience with what works well appreciated. Thanks! -Al
"That'll never work....." |
Liked 706 Times in 283 Posts
I have not tried or know anyone that has used it. The rubber disc on a drill that is sold at Harbor Frieght may work. They claim it's a decal remover and does not hurt the paint. IDK
#3 | |
Liked 358 Times in 83 Posts
Liked 43 Times in 29 Posts
You may want to try a heat gun or hair drier, warm the panel up a bit and use a plastic razor blade
, or a plastic squeegee. I would follow it up with some rubbing alcohol.
Mark Ruset 2048 STK |
Liked 52 Times in 32 Posts
Turtle Wax make an aerosol spray that I just used. Spray it on, let it set a few seconds, soft cloth will remove it all. Works much better than Goo Gone IMO.
SC 707Y |
Liked 1,586 Times in 583 Posts
Heat gun and keep it at the right distance and rubber scraper like as it was suggested.
Liked 50 Times in 28 Posts
![]() ![]() I've used this with great success. |
Liked 92 Times in 26 Posts
3M works great, let the product do its thing and wipe off with a soft cloth.
may take 2 applications on the real tough ones. Take your time , not much force required. |
#9 | |
Liked 91 Times in 51 Posts
Clark |
Liked 22 Times in 16 Posts
