Old 02-24-2021, 10:36 AM   #1
Alan Nyhus
Liked 799 Times in 236 Posts
Default Decal adhesive remover
Not a real tech-y question but here it is.
Removed a bunch of decals and now have to deal with the old, nasty adhesive residue left behind. Goo Gone worked ok on the softer residue..not so good on the harder residue. Same with WD40.
Any experience with what works well appreciated.
Thanks! -Al
"That'll never work....."
Old 02-24-2021, 10:53 AM   #2
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: Decal adhesive remover
I have not tried or know anyone that has used it. The rubber disc on a drill that is sold at Harbor Frieght may work. They claim it's a decal remover and does not hurt the paint. IDK
Jeff Stout is online now   Reply With Quote
Old 02-24-2021, 11:42 AM   #3
nhramnl
Liked 358 Times in 83 Posts
It does work, but you have to be VERY careful when using it. By that, I mean go slowly, and don't push too hard. You will ultimately "get a feel" for where you need to be with pressure and speed, but at first, you most definitely can burn the surface. I found it to be very helpful in speeding-up the job, but was nervous the entire time.
Old 02-24-2021, 11:54 AM   #4
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
You may want to try a heat gun or hair drier, warm the panel up a bit and use a plastic razor blade
, or a plastic squeegee. I would follow it up with some rubbing alcohol.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 02-24-2021, 11:55 AM   #5
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Turtle Wax make an aerosol spray that I just used. Spray it on, let it set a few seconds, soft cloth will remove it all. Works much better than Goo Gone IMO.
SC 707Y
Dano is offline   Reply With Quote
Old 02-24-2021, 12:03 PM   #6
SSDiv6
Heat gun and keep it at the right distance and rubber scraper like as it was suggested.
Old 02-24-2021, 12:37 PM   #7
Terry Witzel
Terry Witzel's Avatar
Liked 50 Times in 28 Posts
I've used this with great success.
Old 02-24-2021, 01:17 PM   #8
Dan Walcott
Liked 92 Times in 26 Posts
3M works great, let the product do its thing and wipe off with a soft cloth.
may take 2 applications on the real tough ones.
Take your time , not much force required.
Dan Walcott is offline   Reply With Quote
Old 02-24-2021, 02:03 PM   #9
cad
cad's Avatar
Liked 91 Times in 51 Posts
I 110% agree with Dano. I just removed 15 year old stickers from the cabinets in my Gold Rush with this and some blue paper towels.
Clark
Old 02-24-2021, 08:34 PM   #10
joe collins
Liked 22 Times in 16 Posts
Thats works great thats what i use
joe collins is offline   Reply With Quote
