#21 |
Sure am...from the doors back ;-)
#22 |
Liked 627 Times in 156 Posts
So you’ve been hard at it, looking a damn sight better than when I first saw it, lol 😂!
Pete Lanciers PAL Automotive Racing Stock 7801 |
#23 |
Liked 98 Times in 31 Posts
[QUOTE=Mark Yacavone;630985]Look what followed us home today...
I see Ford uses the same clear coat at GM..Black car,..in San Diego yet. That's okay...Have d/a, will travel. Leave the paint alone, its a weight savings.......lol What happened to the trailer you built for it? BBB |
#24 | |
[QUOTE=BigBlockBill;635013]
Inspection, VIN, tax, title , permanent plate, and oh yeah, road use fee. (CA. trick they picked up over here) total $191.00 Probably cheap, compared to some states. Leave the paint like that? I guess you don't know me very well..LOL
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 02-22-2021 at 10:22 PM. |
#25 |
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 02-24-2021 at 11:42 AM. |
#26 | |
Liked 373 Times in 129 Posts
[QUOTE=Mark Yacavone;635022]
I know you well...............and I know your extremely fastidious ![]() |
#27 |
Not a lot of bubblepak- ing going on yet..
Little bit.. New countenance here: I decided I didn't want to spend 25 bucks and four hours, polishing headlights..Not when I could get a new pair for 48 bucks, free shipping. ![]() Solid mounts all welded up and fitting to the transaxle and block. I gave the t/a a bath and a spray can rebuild. Hoping for the best ;-) ![]() I remembered that the crossmember that two of the mounts sit on, was rubber mounted too, so I did a quickie solution on that. ![]() This doesn't look much like a header yet, but I promise it will, when I get the head back and put this thing together. ![]()
#28 |
Liked 489 Times in 227 Posts
What class you plan on putting this into ?
Jake Biermann |
#29 |
#30 |
I had a couple more pics that I neglected to include in the last update, so here ya go}
The bracket that holds the alternator, also held the p/s pump and A/C compressor. I attacked it with a Sawzall and left just enough I think.It also bolts to the head. I had to rotate the tensioner to the left and then find the exact right belt. (3 tries) but it oughta work okay. ![]() I had to heat the front hubs with an acetylene torch to get the axle out of them, which , in turn , ruined the wheel bearings..The axle splines were choked with rust but I managed to save them by using small cut off wheel on a Dremel tool to clean them up. It all pressed back together fairly easy . ..A few more parts not covered with grease and rust anymore.. ![]() ![]()
