Liked 1,603 Times in 583 Posts
NHRA released an addendum to the rule book applicable to tech inspections.
http://www.nhra.net/2021/nhraracer/r...n_Rulebook.pdf Although not detailed and/or specific, one noteworthy statement is that under the clauses of the new addendum, they have the authority to look at your electronic data in and outside your car. My belief is that NHRA can request that you provide them your Racepak or similar recording system data and in the case of EFI, your software/tune programs. "By participating in the event, the participant understands and agrees that NHRA and event officials at any NHRA Member Track may at any time inspect, seal for inspection, tear down, and/or conduct testing by any means or method they deem appropriate on a vehicle or any part thereof, including PPE and components that are not affixed to or have been removed from the vehicle and computer or electronic devices and data, including without limitation data preserved away or apart from the vehicle." Last edited by SSDiv6; 02-19-2021 at 03:07 PM. |
Liked 497 Times in 243 Posts
Wonder what they are looking for...
Sounds like something specific although not alluded to?... Hmmm... |
Liked 355 Times in 80 Posts
Liked 63 Times in 14 Posts
How many times do they have to repeat them selves page after page to get there point a cross, once should be enough unless your getting punished !!!!!!!!!, BAD BOY BAD BOY. I guess if we do it right the first time no issues for them to complain about.
#5 | |
Liked 56 Times in 33 Posts
#6 | |
Liked 7,809 Times in 1,748 Posts
Now IMHO, I'm gonna go out on a limb here and guess that they are looking for down-track-timers and what can be used as a down-track-timer. For an example, what's a data-logger (specifically the driveshaft sensor) doing while it's going down the track hooked to the ignition box through the grid. This all MIGHT have something to do with the new staging rules also. Oh, and let's not forget traction-control.
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 02-20-2021 at 11:01 AM. |
I have had "issues" with many NHRA Tech Officials over the years BECAUSE I always ask too many questions. The rules have always been written in a way as to be intentionally vague. I was actually told by one former NHRA Tech "we don't want you asking for permission, we want you begging for forgiveness".
That explains a lot... So that's why the dear in the headlights look when I asked questions... Got it... ![]() This may be more fun than I thought... ![]() |
Liked 903 Times in 237 Posts
Does this new tech mean I have to not use my garage door opener in my pocket? Just asking for a friend
Don Kennedy 7701 SS |
Liked 449 Times in 98 Posts
Drive shaft acceleration profiles of previous runs Elapsed Time from a RacPak can be downloaded to devices that work with the MSD Grid to make timing adjustments down track to run the same drive shaft profile and ET over and over. Or a new drive shaft acceleration profile can be downloaded via Bluetooth to run a different ET so its not so obvious what's going on. People have figured out how to embed the circuitry inside the MSD Grid box making it very difficult for tech officials to spot. However, the Personal Computer (PC) in the trailer will have the illegal software installed on it. The new language makes it clear Tech officials can demand access to the PC. NHRA should be applauded for their efforts to protect the integrity of our sport and attempts to maintain a level playing field for the vast majority or racers that don't use such devices.
Anyone that thinks this is a conspiracy theory or the technology isn't readily available for purchase on the internet, hasn't researched the issue. Last edited by DG; 02-20-2021 at 02:30 PM. |
#10 | |
Liked 359 Times in 103 Posts
I am not saying everyone is using the grid system in this manner however, it is and has been happening. One more item I believe should be outlawed is any counter, drive shaft, wheel or any other type of counter. The tech department is just now starting to catch up with the technology that is available. Just My Take Rick Cates Canyon, TX |
