Old 02-11-2021, 12:01 PM   #11
Default Re: Over Staging
Originally Posted by SGSST109E View Post
I was watching the feed from Orlando when a stocker went in to deep during eliminations and didn't get a red. I thought he should have gone red. Maybe people questioned why not.
I didn't see that. I did see a newbie in SS, fail to courtesy stage ,and was backed up .
Joe C. , who claims to be a sportsman racer, said they were checking the dial -ins , but that didn't appear to be the case, from my vantage point.
Old 02-11-2021, 12:39 PM   #12
340Cuda
Liked 805 Times in 341 Posts
Asking for myself, not a friend...
My question would be if I accidentally deep stage can I backup and light the pre-stage again? What if I back all the way out and come back in?
Bill
Old 02-11-2021, 12:50 PM   #13
novassdude
Liked 136 Times in 49 Posts
The way I read it. It says the stage light so you would need to go all the way thru Pre-stage and Stage to get disqualified and not allowed to back up and restage.
As far as if you accidently went deep in a class where it is not allowed but did not go thru the stage light. Can you back up I think that needs to be clarified by the powers that be. I would think as long as you get backed up before your competitor gets staged you may be ok. But that is just an opinion.
It also says when in the stage process so I would think if you crossed in the process of doing the burn out that would not effect this rule. It may get you tossed if your class does not allow burning out across the starting line. But this rule shouldn't effect that.
novassdude is offline   Reply With Quote
Old 02-11-2021, 12:52 PM   #14
Bill
Tried to post this last night. If the blue lights are on , and the tree starts, either side , the deep or too shallow car goes red. You technically have a split second to re-stage.
At least that's how it used to be. Now? Have to call my lawyer for an interpretation.
Old 02-11-2021, 01:05 PM   #15
rognelson777
Liked 135 Times in 74 Posts
I would not be surprised it is some type of new technique. The latest staging I have seen racers do in the big dollar brackets races with dragsters, after burn out, backing up, they stop at prestage and leave prestage on, awaiting for other driver to prestage.
rognelson777 is offline   Reply With Quote
Old 02-11-2021, 03:04 PM   #16
GTS340
Liked 1,349 Times in 412 Posts
another first round in super stock there was a crew member standing in the stage beam while the other car was pre-staged. The starter had to run out and get the person out of the lights.
Old 02-11-2021, 04:18 PM   #17
jimmyparker
Liked 309 Times in 88 Posts
In the early days of super gas some of the drivers had a indexed magnetic tape on the driveshaft with a sensor sending a signal to a indicator light on the dash. Once they turned the bottom light they would roll in, they knew what value they needed to see on the indicator to keep from deep staging.
NHRA outlawed these devices probably 25-30 years ago.
jimmyparker is offline   Reply With Quote
Old 02-11-2021, 05:08 PM   #18
GTS340
Sounds like to me another way to cheat. Getting a 1320 measurement somehow. I mentioned a long time ago about racing a world champ that only stared at the tach like it was a geiger counter. Burp burp burp right on the dial in a head wind. Jumped out the car and tells his crew "I thought I turned the tire." Nice!
Old 02-12-2021, 12:25 AM   #19
Wink Re: Over Staging
Question..Race Pack type onboard loggers use a driveshaft counter /reader, right? And lots of new cars have digital dashes, right? Turn the key off and they go blank, right?
Ah, never mind..This is silly
Old 02-12-2021, 12:56 AM   #20
GTX JOHN
[QUOTE=GTS340;634165]Sounds like to me another way to cheat. Getting a 1320 measurement somehow. I mentioned a long time ago about racing a world champ that only stared at the tach like it was a geiger counter. Burp burp burp right on the dial in a head wind. Jumped out the car and tells his crew "I thought I turned the tire." Nice![/QUOTE
Perhaps not even very long ago?
That is all I will say!
John Irving
741 Stock
741 Super Stock
