Liked 1,345 Times in 410 Posts
Like Gregg and Mike I thought they removed deep staging and turning on both light then backing out. I think it use to mess up the staging timer. Every time I see it now I question why the same folks do it on a normal routine and are allowed. Usually I have to wait to make sure my dial is correct before I pre-stage as the pair in front are still running their race. I try not have a senior moment by mistake. Many years ago we did a couple dry hops after the burn out.
Paul Haszlauer |
Liked 126 Times in 61 Posts
I was watching the feed from Orlando when a stocker went in to deep during eliminations and didn't get a red. I thought he should have gone red. Maybe people questioned why not.
#3 | |
Liked 5,125 Times in 1,953 Posts
Joe C. , who claims to be a sportsman racer, said they were checking the dial -ins , but that didn't appear to be the case, from my vantage point.
Liked 802 Times in 339 Posts
Asking for myself, not a friend...
My question would be if I accidentally deep stage can I backup and light the pre-stage again? What if I back all the way out and come back in? Bill |
Liked 136 Times in 49 Posts
The way I read it. It says the stage light so you would need to go all the way thru Pre-stage and Stage to get disqualified and not allowed to back up and restage.
As far as if you accidently went deep in a class where it is not allowed but did not go thru the stage light. Can you back up I think that needs to be clarified by the powers that be. I would think as long as you get backed up before your competitor gets staged you may be ok. But that is just an opinion. It also says when in the stage process so I would think if you crossed in the process of doing the burn out that would not effect this rule. It may get you tossed if your class does not allow burning out across the starting line. But this rule shouldn't effect that. |
#6 | |
At least that's how it used to be. Now? Have to call my lawyer for an interpretation.
Liked 135 Times in 74 Posts
I would not be surprised it is some type of new technique. The latest staging I have seen racers do in the big dollar brackets races with dragsters, after burn out, backing up, they stop at prestage and leave prestage on, awaiting for other driver to prestage.
another first round in super stock there was a crew member standing in the stage beam while the other car was pre-staged. The starter had to run out and get the person out of the lights.
Liked 219 Times in 87 Posts
Just so we are on the same page , over staging = you deep staged by mistake for any reason you are out . And not just a double bulb mistake and you must back out and re-stage . I can't recall the last time I saw it happen but it makes you think twice on taking an extra bump or 2 if you've been alittle on the late side of the tree or a hot greasy track .
#10 | |
