Liked 727 Times in 221 Posts
Re: intake gaskets-- Back in the day that I worked in dealerships,'78-80, and Los Angeles County Mechanical department and I worked on mostly sheriff's cars, the iron intakes on the 78-79 Novas and Malibu's had an iron intake and at some point they quit using front and rear gaskets on the intakes in favor of RTV. All the 80-83 Malibus were 305's, and they had aluminum intakes. They all had RTV on the front and rear of the intake. We bought the orange GM RTV in large cylinders with a nozzle and a cap, and we used a caulking gun to apply it. It took a lot of oil leak comebacks with it. Same with valve covers. The main thing after all the fly cutting and resurfacing takes place is to make sure enough material was taken off of the manifold front and rear to ensure that the side gaskets were compressed adequately to seal up properly.
Greg, At this point we're "trial and error" every step of the way, pretty much change your ways till the failures stop. Seems as though every action to fix a problem has a reaction that creates another. I think we've learned a lot this go round just being able to see some used parts to verify success or failure. I feel like we've closed up some variances hoping it shows power increases, if that works we'll keep squeezing it harder.
Todd Greene |
Liked 336 Times in 183 Posts
TODD check your PM --Dick
Got it in Yesterday afternoon.
Todd Greene |
![]() Looks like you could use a Derby City fender cover ;-)
Yes, we're laying all over it. Not ideal.
Todd Greene |
Got a bit done today, balancer and crank pulley are on, alternator is on, clutch, bellhousing and trans are in. Probably just work on getting small stuff buttoned up tomorrow, also going to order a new driveshaft.
Todd Greene |
