Had to go to work today (total BS
Todd Greene |
Cleaned parts, finished rings and bearings on all but one piston, ran out of spirolox. Back to it tomorrow.
Todd Greene |
Filled some holes, fit the balancer hub and started working on the cam.
Todd Greene |
I think the rebuild is more exciting than the first time we put this one together, we get to see things from a different pespective... the used parts perspective. I've learned a lot and one things for sure, this engine was faster when it was new by a fair bit, last couple races were 1/8 mile and we're a minimum .25 slower to the 1/8 than our best. I'm going to assume the culprit was that the engine wasn't sealed up well with a few cylinders leaking from the valves which cannot be ideal. Also, completely my fault because I didn't know any better but there was condensation in the engine and I guess it was because we really never got the car that hot so the oil never got hot enough I guess. After we would warm the car up better the condensation problem seemed to stop, unfortunately the cylinders and rings had evidence of rust so that didn't help seal it up either. I think we're going to get on a strict regimen of fogging the engine after races as well.
Todd Greene |
Liked 705 Times in 219 Posts
These stocker motors we have built for the last 10 years or so sure resemble Super Stock motors more and more. As far as most of the trick parts any more, especially rods, it seems to enhance engine longevity more than about anything else. It's good to have a motor that you can lean on without worrying about it, however. One thing is for sure--technology marches on.Let's see it in another 10 or so!
Checking checking checking. Takes a while because I need to check, re-check, verify my re-check and then have someone else verify that
Todd Greene |
During all the engine explosions we lost a nice set of rings I'm told, now I didn't know much about rings but I like to think I now know more, only a fraction, but more. And as the education continues I'm told that as much as 15% of total horsepower is lost to friction, which equates to a good bit. Now on to my comment, this engine had a set of speed pro rings that in the end I wasn't happy with but that's personal. I now have a set equivalent to the set we initially destroyed and I SO wish I had measured the engines resistance before it came apart because now it's way way easier to spin over with these rings.
Todd Greene |
