Old 01-15-2021, 03:53 PM   #1
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: H-I-J '76 Nova re-fit.
I have heard not to use a tool steel lifter on a steel cam, but never saw what happens if you do. Treated and coated lifters would be the answer. What did it do to the cam lobe? Also, do you suppose that those used steel lifters could be coated? Might pay to find out.
Old 01-15-2021, 05:57 PM   #2
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
Default Re: H-I-J '76 Nova re-fit.
I have had a set of tool steel lifters repaired. you should be able to then coat them.
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
Old 01-15-2021, 09:14 PM   #3
Nmbr1GMfan
Thanks Keith, I'll hold onto them.
Todd Greene
Old 01-15-2021, 09:19 PM   #4
Nmbr1GMfan
Not a very productive day today but plugging away.
Todd Greene
Old 01-16-2021, 09:47 PM   #5
Nmbr1GMfan
Had to go to work today (total BS ) for a few hours but still managed to get over and get some work done. Measured for spring setup and started putting rings on the pistons.
Todd Greene
Old 01-17-2021, 07:20 PM   #6
Nmbr1GMfan
Cleaned parts, finished rings and bearings on all but one piston, ran out of spirolox. Back to it tomorrow.
Todd Greene
Old 01-18-2021, 09:14 PM   #7
Nmbr1GMfan
Filled some holes, fit the balancer hub and started working on the cam.
Todd Greene
Old 01-15-2021, 09:12 PM   #8
Nmbr1GMfan
Cam isn't hurt, I think I got it just before it really started to do some real damage.
Todd Greene
