Old 01-13-2021, 10:25 AM   #1
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: H-I-J '76 Nova re-fit.
How'd Jim do on those heads?
Old 01-13-2021, 10:57 AM   #2
Nmbr1GMfan
Jim who?
Todd Greene
Old 01-13-2021, 12:23 PM   #3
Nmbr1GMfan
Trying a different lifter this time.
Todd Greene
Old 01-14-2021, 09:33 PM   #4
Nmbr1GMfan
I'll assume I'm not the ony person that does stupid sh!t. I usually do this when I just don't know any better, not because I don't care to do it properly. So on that theme, I've recently learned that it's not a wise move to use a tool steel lifter on a billet core cam... aparently the lifter needs a DLC coating or something-er-other. So this is what the lifter will look like if you do it wrong, sort of looks like its cracking on the surface then pulls what looks like metal slivers off the lifter. DO NOT TRY THIS AT HOME!
Todd Greene
Old 01-14-2021, 10:15 PM   #5
Nmbr1GMfan
We've had a bit of an issue breaking the lower o-ring on the distributor so I went in and gave the block a little more taper. Then wash wash wash!
Todd Greene
Old 01-15-2021, 10:58 AM   #6
Alan Nyhus
Liked 799 Times in 236 Posts
Originally Posted by Nmbr1GMfan View Post
.....I've recently learned that it's not a wise move to use a tool steel lifter on a billet core cam... apparently the lifter needs a DLC coating or something-er-other.
Good catch, Todd. -Al
"That'll never work....."
Old 01-15-2021, 11:07 AM   #7
Nmbr1GMfan
I only caught it after I tore something up hahaha.
Todd Greene
Old 01-15-2021, 03:53 PM   #8
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: H-I-J '76 Nova re-fit.
I have heard not to use a tool steel lifter on a steel cam, but never saw what happens if you do. Treated and coated lifters would be the answer. What did it do to the cam lobe? Also, do you suppose that those used steel lifters could be coated? Might pay to find out.
