Old 01-06-2021, 04:57 PM   #11
bykr
Liked 167 Times in 81 Posts
Default Re: Starting line ratio for manual transmission application
Originally Posted by Jim Caughlin View Post
The shift light is on in my car about as fast as I dump the clutch, I'm in 2nd well before the 60' timer. Looking at the data logger, the engine never drops below 6,000 and is at 8400 within 1 second. That's with a 3.29 1st gear, 6.50 rearend and 28" tall tire. I would guess that your car would be about the same. The ratio is so low that I usually drive around the pits in 2nd gear, I can outwalk the car in 1st!
Yes, very similar, never gets below 6k and first is only used on the starting line.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 01-07-2021, 09:41 AM   #12
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Originally Posted by tavbfl View Post
Thank you all for your comments! The chart from Black Magic was exactly what I was looking for. To answer some of your questions, my 60 ft has been between 1.38 and 1.46, 330 ft between 4.10 and 4.15, and my first gear is 2.80. Finding gears for the Doug Nash is a challenge so this can be my callout to any racers that have them in a box on the shelf somewhere. I am looking to change to 5.57 gears as I am crossing at 6300 with the 5.14's and motor makes power to 7000. I am also dialing in a slipper clutch for the first time so it's a matter of optimizing my combo and then focusing on consistency.
You’ll need more rear gear to cross finish line at least 7500 rpm
Old 01-07-2021, 01:58 PM   #13
Robin Lawrence
Sponsor
Liked 716 Times in 120 Posts
Lots of good information here. I just finished my stick shift Mustang and have made 2 runs before the track closed. Started out with a 3.32 first and a 5.43 rear gear.
I plan to test a few different first gear as well as rear gear ratio's this year.
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 01-07-2021, 02:24 PM   #14
BRETV
Liked 776 Times in 199 Posts
What class Robin?
Bret Velde
2003 ??/SA
BRETV is offline   Reply With Quote
Old 01-07-2021, 02:55 PM   #15
Robin Lawrence
Sponsor
Originally Posted by BRETV View Post
What class Robin?
Bret Velde
2003 ??/SA
FS/H 2012 Cobra-Jet Mustang with the 325HP Coyote G Force GF5R trans
STK 308
SS 3088
Old 01-10-2021, 02:33 AM   #16
Adger Smith
Liked 880 Times in 311 Posts
Years ago when changing from a good performing auto to a stick we just used 20% more ratio as a starting point. It may be a little different today with the trick clutches. That got us in the ball park.
Adger Smith (Former SS)
Old 01-10-2021, 04:23 PM   #17
Eddie Rezac
Liked 63 Times in 7 Posts
Smile Re: Starting line ratio for manual transmission application
Check my ad in parts for sale section! Eddie Rezac
Eddie Rezac is offline   Reply With Quote
