Old 12-30-2020, 05:21 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default 200 ultrabell
What bolts are yall using to put on a 200 metric ultrabell. They don't offer a kit for it nor do they come with it?
jamie2370 is offline   Reply With Quote
Old 12-30-2020, 05:46 PM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: 200 ultrabell
I took the stock metric oil pump retaining bolts length and added length to account for the thickness of the Ultra Bell. Found what I needed at a local Fastenal, specifying grade 8 bolts.
Jim Kaekel 3836 STK
Old 12-30-2020, 11:06 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
It is very important that the pump is on center with the crankshaft . The procedure is similar to dialing in a bellhousing on a stickshift setup . Just bolting up a JW bell using the existing pump bolts will cause the pump to have a lot of runout . Bolt up just the bell to a good engine block and tram in the pump bushing to the crankshaft , Dowel pin the pump body to the bellhousing , and you should be good to go .
ss3011 is online now   Reply With Quote
Old 12-31-2020, 08:49 AM   #4
LS1Racer
LS1Racer's Avatar
Liked 6 Times in 6 Posts
FWIW M8x1.25x50mm is the size JW tech gave me when I contacted them.
LS1Racer is offline   Reply With Quote
Old 01-01-2021, 02:24 PM   #5
jmantle
Liked 172 Times in 81 Posts
Just finished one, M8 x 1.25 x 55 class 10.8 with hard flat washers. I bottom tapped the holes in the case to make sure there was enough thread depth.
Don't forget the o-rings.
Jim Mantle V/SA 6632
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
